Indoor CO₂ Air Monitoring Solution for LoRaWAN®
Improve indoor air quality with a cost-effective LoRaWAN®-enabled CO₂ monitoring system.
School A, located in a busy city center, is grappling with elevated indoor carbon dioxide (CO₂) levels - a silent issue adversely impacting students' health and concentration. Although CO₂ is generally harmless at low concentrations, high levels signal poor indoor air quality and a buildup of other harmful pollutants. Current solutions have proven costly and ineffective. Therefore, the school urgently seeks a real-time CO₂ monitoring system. This initiative could greatly boost student well-being and focus, while also reducing the risks tied to variable air quality. It's a step towards ensuring a consistently safe and productive learning space amidst the urban hustle.
Problem
High levels of CO₂ can cause health problems and discomfort for occupants. Regulations require better ventilation in enclosed spaces, such as classrooms and school facilities, but implementing effective IoT solutions for CO₂ monitoring is challenging.
School A is facing difficulties in making sure that its coverage is complete, methods are cost-effective, and systems are easy to install and maintain. These challenges are made more difficult because the school is located in an urban area, where polluted air can easily enter the building. This means that finding a solution to these problems will require a sophisticated and practical approach.
Use Case
In response to the need for a safe and healthy learning environment, School A adopted the Qingping LoRaWAN® CO₂ Monitoring Sensor.
Picture a classroom or teacher’s lounge where unobtrusive devices efficiently monitor air quality. These power-efficient devices cover the school's large premises, including areas with potential signal blockages.
The system is easy to install and manage. In case of interference, devices automatically switch to backup channels, ensuring reliable performance. The network's star topology simplifies operations and manages bandwidth.
This strategic move by School A has effectively addressed the problem of indoor air quality, enhancing student health and focus through technology.
Benefits
Efficient Energy Use: The low power consumption of the LoRaWAN devices ensures they can operate for extended periods without needing frequent recharging or replacement.
Long-Range Capabilities: The system can transmit data over vast distances, making it suitable even in indoor environments with potential wireless signal obstructions.
Affordability: Compared to other wireless technologies, LoRaWAN devices are generally less expensive, offering a cost-effective solution.
Ease of Deployment: The simplicity of setting up and managing the LoRaWAN network reduces the hassle associated with network management.
Reliability: With their high reliability and ability to switch to backup channels if interference is detected, LoRaWAN devices ensure consistent performance.
Improved Return on Investment: The deployment of a LoRaWAN network not only addresses the immediate needs of the school but also enhances the return on investment over time by reducing operational costs and improving overall efficiency.
Success Factors
Whether you're a solution reseller or a solution integrator, here’s how you can convince network users and end-users to adopt this use case through project experience:
Constructing a Prototype: Initiate a pilot project involving three CO₂ sensors and an indoor LoRaWAN gateway. A prototype can aid regulators in grasping the advantages of the solution.
Establishing CO₂ Concentration Standards: Work together with local authorities to determine permissible CO₂ concentration levels and set rules for preserving air quality.
Partnering with Major BMS Providers: To expand this solution to schools or buildings, think about partnering with prominent Building Management System (BMS) providers via protocols such as Bacnet or MQTT
What's next?
We can connect you with the solution provider.
Depending on the challenges you face, we can also use the RAK product ecosystem to quickly build a solution with minimal capital investment tailored to your needs. Our goal is to lower the barrier to adopting IoT solutions and help you solve your business problems.
Looking for something else? Browse other use cases or submit your business problem to the Real IoT Marketplace. We’ll do our best to create a solution that fits your needs.
Are you a distributor and interested in marketing this use case? Join the RAK Solution Partner Program and start distributing this use case to your customers.
Are you a solution creator or device manufacturer? If you have solutions or products that you believe are suitable for our customers, submit a use case to be featured in the Real IoT Marketplace. Once approved, they will be published on the platform.
Solution Kit
Experience the convenience and adaptability of the Real IoT Kit solution kit, featuring immediate plug-and-play functionality and the flexibility to meet your unique needs.
Real IoT Kit
But we don't stop at selling you a solution. With our deep networking knowledge and range of products, we can also help you deploy and scale your IoT solution when you need it.
Easy 3-Step LoRaWAN Solution
Easily build and manage IoT projects with Datacake's low-code platform. We handle the integration, so you can start using it right away. Give your customers the power to build custom solutions and a fully-branded IoT experience.
Network Options
Cloud
Local
Helium
IoT solutions kits have pre-provisioned gateways and devices onboarded on TTI LNS. However, you still have the option to configure your gateways and devices to work with other LNS like Helium public network or even on a private network via locally installed LNS like Chirpstack. This flexibility is important and depends on your IoT business needs.
Does this use case help solve a problem for you or someone you know?
If you would like to know more, please fill in the form below with your details, and we will introduce you to the solution provider via email.
Uploaded on 05/11/2023
