Wireless Temperature and Humidity Sensor: Monitoring and Preventing Condensation
Take control of your business environment with an automated, real-time temperature and humidity monitoring system.
Company A is a leading food manufacturer and distributor with warehouses spread across the country. They specialize in perishable goods, making the climate within their warehouses crucial to the quality and safety of their products. The company, however, had been struggling with an issue of condensation in their warehouses. The condensation was causing spoilage, equipment breakdown, costly repairs, and affecting the shelf-life of their products. A wireless temperature and humidity sensor solution can be implemented to help maintain optimal conditions and prevent condensation.
Problem
Company A had multiple facilities, each requiring specific environmental conditions to ensure the well-being of their employees and the smooth functioning of their equipment. They were faced with a challenge: it was difficult to maintain the perfect environment for their sensitive production processes. Here are the specific issues they encountered:
- Rust, Rot, and Mold: Excessive moisture led to the development of rust, rot, and mold. These issues not only threatened the quality of stored goods but also increased waste in warehouse operations.
- Temperature and Humidity Fluctuations: Variations in temperature and humidity were negatively impacting product quality and operational efficiency.
- Equipment Issues: The damp environment was harmful to the equipment, causing frequent breakdowns, which resulted in costly repairs.
- Manual Monitoring Limitations: The company was relying on manual monitoring of temperature and humidity levels, which proved to be inefficient and prone to human error. This made it difficult for them to effectively control these issues.
Use Case
Enter the Milesight Wireless Temperature and Humidity Sensor - an advanced solution to monitor and prevent condensation. This wireless sensor provides real-time temperature and humidity readings, allowing users to set thresholds and receive alerts when critical levels are reached. These features make it a powerful tool in predicting and preventing condensation events.
After market research, Company A decided to integrate the Milesight Wireless Temperature and Humidity Sensor into their facilities.
They strategically placed the sensors in key areas where condensation was most likely to occur, such as in production floors and storage rooms with cold walls and high-humidity areas.
The solution provided the company with data that they needed to address the business problem. Company A could detect any significant drops in temperature or spikes in humidity, indicating a higher probability of condensation formation. When critical thresholds were reached, the system would trigger alerts. This allowed the team to take immediate preventive or corrective measures. Moreover, the facilities team could monitor temperature and humidity levels in real time via a user-friendly dashboard.
Benefits
Enhanced product quality and safety by preventing the formation of condensation.
Reduced equipment maintenance costs by preventing any damage to the sensitive equipment in the room.
Improved operational efficiency through proactive monitoring and alerts.
Streamlined temperature and humidity control, leading to energy savings.
Increased confidence and trust among clients due to better storage conditions.
What's next?
We can connect you with the solution provider.
Depending on the challenges you face, we can also use the RAK product ecosystem to quickly build a solution with minimal capital investment tailored to your needs. Our goal is to lower the barrier to adopting IoT solutions and help you solve your business problems.
Looking for something else? Browse other use cases or submit your business problem to the Real IoT Marketplace. We’ll do our best to create a solution that fits your needs.
Are you a distributor and interested in marketing this use case? Join the RAK Solution Partner Program and start distributing this use case to your customers.
Are you a solution creator or device manufacturer? If you have solutions or products that you believe are suitable for our customers, submit a use case to be featured in the Real IoT Marketplace. Once approved, they will be published on the platform.
Solution Kit
Experience the convenience and adaptability of the Real IoT Kit solution kit, featuring immediate plug-and-play functionality and the flexibility to meet your unique needs.
Real IoT Kit
But we don't stop at selling you a solution. With our deep networking knowledge and range of products, we can also help you deploy and scale your IoT solution when you need it.
Easy 3-Step LoRaWAN Solution
Easily build and manage IoT projects with Datacake's low-code platform. We handle the integration, so you can start using it right away. Give your customers the power to build custom solutions and a fully-branded IoT experience.
Network Options
Cloud
Local
Helium
IoT solutions kits have pre-provisioned gateways and devices onboarded on TTI LNS. However, you still have the option to configure your gateways and devices to work with other LNS like Helium public network or even on a private network via locally installed LNS like Chirpstack. This flexibility is important and depends on your IoT business needs.
Does this use case help solve a problem for you or someone you know?
If you would like to know more, please fill in the form below with your details, and we will introduce you to the solution provider via email.
Uploaded on 05/11/2023
