DIY Outdoor Gateway
DIY Outdoor Gateway RAK7249
  • Enterprise grade network gateway
  • LoRaWAN™ Stack Inside
  • Complete Hardware specification with LoRa concentrator, Cellular, GPS and WiFi
  • Supports Power-over-Ethernet (PoE)
  • Backup battery sustained operation for 5 hours
  • IP67 waterproof enclosure with cable gland
Pilot Gateway
RAK Pilot Gateway RAK7243C
  • Preassembled Full LoRaWAN Gateway
  • Supports all 8 channels and spreading factors
  • Semtech SX1301 with up to -142.5 dBm sensitivity
  • Band support: 433MHz, 470MHz, 865MHz, 868MHz, 915MHz, 920MHz, 923MHz
  • Max output power 25.5 dBm
  • New design integrates Ublox MAX-7Q GPS module
Communication Technologies
We use the latest technologies and tools in order to create a better product that not only works great, but it is easy easy to work with too.
Low-cost physical layer that enables extremely long range wireless communication with optimized energy efficiency and robust signal.
New cellular technology specifically designed for the needs of applications targeting Internet-of-Things (IoT) or Machine-to-Machine (M2M) communications.
With simple development, you can add Alexa voice driver to your smart products and make real-time voice interaction with Alexa via microphones and speakers.
Digital transmission of high-definition video, audio, and data signals. Build drones and surveillance systems; the possibilities are endless.
Your Bridge to IoT Solutions
We develop market-oriented and easy-to-use IoT Building Blocks of MCUs, communication modules, and sensors in a Lego-like system.
That means you can accelerate the time of your IoT application to develop from prototype to commercial.
Our Advantage IoT Block Portfolio
Our Advantage
Lego-like Approach
Lego-like Approach
Easy and Ready to Use
Application Building Blocks
Modular and Flexible Configuration
Enterprise Ready
Enterprise Ready
Experienced Core Engineering Team
Product Performance Tests
Quick Support
Quick Support
Online Support Center
Developers’ Community
Documentations & Software
IoT Block Portfolio
The technical competency of RAK founder and his team in the IoT industry has brought numerous achievements and breakthroughs each year.
We strive to patent unique solutions and have partnered with some of the big IoT players like Apple, Amazon, and Microsoft.
RAKwireless continues to bring easy to implement solutions to IoT developers and connect the world like never imagined before.
Learn more
IoT Block Portfolio Lego
**Do you want to be our Value Added Reseller? Apply now
